SullyMan95
Jun 02, 2021Aspirant
Remove custom firmware
I have a Netgear router that someone has loaded a custom firmware on. They also removed the lable on the bottom that had all of the product information (serial #, model #, default logins, .ECT). All I...
Jun 02, 2021Guru - Experienced User
Your best bet?
Go to the forum with the type of firmware is loaded on it and check about how to remove their firmware to run stock firmware.
Or use the custom firmware. Sometimes its actually decent and works.
SullyMan95
I will have to look into that, but I'm not expecting it to work as I believe the firmware is from a remote management company that does not provide public software/firmware access
- plemansJun 03, 2021Guru - Experienced User
That doesn't tell us a whole lot.
