SullyMan95
Jun 02, 2021Aspirant
Remove custom firmware
I have a Netgear router that someone has loaded a custom firmware on. They also removed the lable on the bottom that had all of the product information (serial #, model #, default logins, .ECT). All I...
michaelkenward
Jun 04, 2021Guru - Experienced User
SullyMan95 wrote:
I have tried to reset the router with it's button and flash the factory firmware with TFTP2.exe and it fails.
Very old school. Why faff around with third party software when Windows can do the job?
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
This also explains how to enable TFTP on a Windows PC.
TFTP isn't the easiest operation, so if you are forced to use it try a web search for videos that guide you through the process.
For example:
Different device, but the approach is the same.
The good news is that TFTP has rescued many a dead device.
