ward74
Jul 13, 2017Aspirant
repeatedly receive:Secure connection failed
Hello, OS Windows 10 R6200 V2 Firmware Version V1.0.3.12 It does not matter what browser I use, when I open it I see "Secure connection failed". If I close and reopen it I may or may not have acce...
- Jul 13, 2017
Hi ward74,
1. Does the issue persist when you bypass the router (connect straight to the modem)?
2. Do you have the ReadySHARE Vault program installed? If yes, are you using it?
3. If you are not using it, you may uninstall the program.
4. If you are, please try uninstalling and re-installing the program.
Dexter
Community Team
DexterJB
Jul 13, 2017NETGEAR Moderator
Hi ward74,
Dexter
Community Team
