darkwolf's avatar
darkwolf
Replacement for R6400
So I have determined my usb 3 port on my router is shot, usb 2 works fine. I have factory reset the router, tried another cable, tried another storage device, even installed ddwrt, none of them will ...
  • darkwolf's avatar
    darkwolf
    Feb 18, 2018
    Called up netgear, they refused to honor the warranty because the hard drives I use aren't on their compatibility list, even though they worked fine for the past 10 months and works fine on the usb 2 port. Company is just garbage and won't be buying from them again in the future.
