topcorner18
Jan 26, 2022Aspirant
Replacement for Readyshare vault that was discontinued
Greetings, Was doing some home network reconfiguration recently and found my Readyshare vault did not seem to be working. I reconnected the drive and got it going again but could not get e-mail ...
michaelkenward
Jan 27, 2022Guru - Experienced User
topcorner18 wrote:
What are we supposed to use to backup our data now to a router connected USB Drive?
What do you want to achieve with this setup? If it is a simple backup regime that is dead easy.
I do this all the time with ReadySHARE and various different bits of software. This is in a network with a handful of PCs. a bunch of Ethernet NAS and ReadySHARE USB. I recently discovered that I can use a Seagate 8TB USB drive on ReadySHARE and then plug two more drives into the USB ports on the 8TB USB.
I can even get at the ReadySHARE drives from afar, using ReadyCLOUD.
