topcorner18
Jan 26, 2022Aspirant
Replacement for Readyshare vault that was discontinued
 Greetings,     Was doing some home network reconfiguration recently and found my Readyshare vault did not seem to be working.  I reconnected the drive and got it going again but could not get e-mail ...
michaelkenward
Jan 27, 2022Guru - Experienced User
topcorner18 wrote:
What are we supposed to use to backup our data now to a router connected USB Drive?
What do you want to achieve with this setup? If it is a simple backup regime that is dead easy.
I do this all the time with ReadySHARE and various different bits of software. This is in a network with a handful of PCs. a bunch of Ethernet NAS and ReadySHARE USB. I recently discovered that I can use a Seagate 8TB USB drive on ReadySHARE and then plug two more drives into the USB ports on the 8TB USB.
I can even get at the ReadySHARE drives from afar, using ReadyCLOUD.
topcorner18
Jan 27, 2022Aspirant
Thanks for the quick replies folks. Maybe I am missing something, the press release said ReadyShare Vault would no longer be supported and may not work going into the future. Is the "Vault" a separate part of the ReadyShare Application?
So I have a drive connected to the R7000 USB. I assume that is now a Readyshare USB drive but there is no backup software which was "The Vault" portion? That being the case what backup application would you recommend that would serve the same purpose as the discontinued VAULT software.
- michaelkenwardJan 27, 2022Guru - Experienced UserYour USB drives are just drives connected to your network. You can use whatever software you like to backup files from your PC or other stuff on your network to these drives. I use Synchback, Acronis and Easeus to run various backup tasks. If you already have backup software, I would be surprised if it can't use your READYSHARE drives at the receiving end. You might even find that it is more capable than Vault. - topcorner18Jan 28, 2022AspirantThank you Michael. Now I see it on my network. I will tie it into my existing WD Backup software. Really appreciate the quick help! - michaelkenwardJan 28, 2022Guru - Experienced User
 topcorner18 wrote:
 Now I see it on my network. I will tie it into my existing WD Backup software. You may find that it is a lot better than the Netgear option.
