topcorner18
Jan 26, 2022Aspirant
Replacement for Readyshare vault that was discontinued
Greetings, Was doing some home network reconfiguration recently and found my Readyshare vault did not seem to be working. I reconnected the drive and got it going again but could not get e-mail ...
topcorner18
Jan 27, 2022Aspirant
Thanks for the quick replies folks. Maybe I am missing something, the press release said ReadyShare Vault would no longer be supported and may not work going into the future. Is the "Vault" a separate part of the ReadyShare Application?
So I have a drive connected to the R7000 USB. I assume that is now a Readyshare USB drive but there is no backup software which was "The Vault" portion? That being the case what backup application would you recommend that would serve the same purpose as the discontinued VAULT software.
michaelkenward
Jan 27, 2022Guru - Experienced User
Your USB drives are just drives connected to your network. You can use whatever software you like to backup files from your PC or other stuff on your network to these drives. I use Synchback, Acronis and Easeus to run various backup tasks.
If you already have backup software, I would be surprised if it can't use your READYSHARE drives at the receiving end. You might even find that it is more capable than Vault.
