topcorner18
Jan 26, 2022Aspirant
Replacement for Readyshare vault that was discontinued
Greetings, Was doing some home network reconfiguration recently and found my Readyshare vault did not seem to be working. I reconnected the drive and got it going again but could not get e-mail ...
michaelkenward
Jan 27, 2022Guru - Experienced User
Your USB drives are just drives connected to your network. You can use whatever software you like to backup files from your PC or other stuff on your network to these drives. I use Synchback, Acronis and Easeus to run various backup tasks.
If you already have backup software, I would be surprised if it can't use your READYSHARE drives at the receiving end. You might even find that it is more capable than Vault.
topcorner18
Jan 28, 2022Aspirant
Thank you Michael. Now I see it on my network. I will tie it into my existing WD Backup software. Really appreciate the quick help!
- michaelkenwardJan 28, 2022Guru - Experienced User
You may find that it is a lot better than the Netgear option.
- trev5708Mar 28, 2022Aspirant
I'm also looking for a replacement to the old software, maybe someone on here can help me out. I have a hard drive hooked up the the R7000 so that the four computers in the office can access the drive at the same time, and it acts as a documents folder on each of our computers. I love the fact that I can access it remotely as well, and would like to keep this feature. The only thing is I can't seem to find a program that will back up/sync the hard drive that's plugged into the router. If anyone has a suggestion, that would be extremely helpful.
- michaelkenwardMar 28, 2022Guru - Experienced User
There is a difference between a backup service and one that lets you access files, although there may be ways to turn access into a backup service.
For access I use ReadyCLOUD to transfer and access files.
But this is a single user option. You may be able to share access, but I have not tried a multi-user approach.
To be honest, I think you are asking a down market consumer de vice to provide a business service.
An office should be able to afford something like a ReadyNAS store.
Then there are cloud services like OneDrive.
ReadySHARE is a pretty poor alternative to proper Ethernet NAS.
