reidrobe
Nov 11, 2016Follower
Replacing my old N600 with my new N900 Wifi Router. Set up questions
I am replacing my old N600 with my new N900 Wifi Router. When I hook up the new router will it automatically be ready to go or are there specific steps I must follow?
- Nov 14, 2016
reidrobe Sometimes you may still need to configure the router. You may see the following links below to set it up.
How to Install a NETGEAR Wireless N-Router with the Installation Assistant
michaelkenward
Nov 11, 2016Guru - Experienced User
The manual and installation guide for the R6050, as listed in your footer, if that is what you plan to buy, are here:
R6050 | Product | Support | NETGEAR
ElaineM
Nov 14, 2016NETGEAR Employee Retired
