ddspike
Jul 07, 2021Aspirant
reset frequency for br6400
arlo not working any more said to reset frequncey now set at 2.4ghz how to i do that
Jul 07, 2021Guru - Experienced User
1. you have the R6400?
2. what firmware is on it?
3. What gateway is it connected to?
4. What actual issue are you having? your description doesn't tell us much.
ddspike
Jul 08, 2021Aspirant
yes r6400 192.1`68.1.1 had arlo conect working fine recharged batteries they became un connected did re start and everything they said now saying need to change frequency set at 2.4 ghz or do you have any idea on what to do
