marymaryk
Dec 30, 2021Follower
Reset password for 2.4ghz, cannot connect. Wifi 5 is fine (AC1750 Smart Wifi Router)
Hello, I am having issues connecting to my default wifi (2.4 GHz). I have renamed the network names of both my Netgear Wifi 5 GHz and Netgear Wifi 2.4 GHz, however I can only connect to the 5 GHz wit...
wcalifas
Dec 30, 2021Prodigy
Does that happen with only one device or all devices? you might want to try and go to the settings of your device and click where it says "forget" this network but again don't know what device you're using.
