naturalblue
Apr 20, 2021Aspirant
Reset prosafe fs116p
My switch appears to have frozen. 5 leds are on constantly. When I plug in a cable I don't get anything. There appears to be no reset button on the switch. Does anyone know how I can reset/factory re...
antinode
Apr 20, 2021Guru
> 5 leds are on constantly. [...]
_Which_ "5 leds are on constantly"? Colors? Whether or not a cable
is connected to the corresponding port?
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get some. Read.
> [...] When I plug in a cable [...]
A cable normally has two ends. What's the other end doing?
> [...] I don't get anything. [...]
Does that mean that the corresponding port-status LEDs stay dark, or
what?
> [...] There appears to be no reset button on the switch. [...]
What's to reset? It's an unmanaged switch.
> [...] should I just bin it[?]
If its port-status LEDs do not agree with reality, and data don't get
through it, then I'd guess that it's junk. In that case you might want
to look for a replacement switch with gigabit/s capability.
Are you using its PoE capability?
- naturalblueApr 21, 2021AspirantLast 5 less aare on. 12-16. Leds are green. Stay that way whether something is plugged in or not.
Other port less are dark. Stay that way whether a cable is plugged in or not.
Cable that is being used is connects to a laptop. It has been tested and works.
I am currently not using the Poe to power anything.- antinodeApr 21, 2021Guru
> Last 5 less aare on. [...]
"Last" is a bit vague, but it sounds fried.
If you don't expect to use PoE, then replacing the thing should be
cheaper.
