naturalblue
Apr 20, 2021Aspirant
Reset prosafe fs116p
My switch appears to have frozen. 5 leds are on constantly. When I plug in a cable I don't get anything. There appears to be no reset button on the switch. Does anyone know how I can reset/factory re...
naturalblue
Apr 21, 2021Aspirant
Last 5 less aare on. 12-16. Leds are green. Stay that way whether something is plugged in or not.
Other port less are dark. Stay that way whether a cable is plugged in or not.
Cable that is being used is connects to a laptop. It has been tested and works.
I am currently not using the Poe to power anything.
antinode
Apr 21, 2021Guru
> Last 5 less aare on. [...]
"Last" is a bit vague, but it sounds fried.
If you don't expect to use PoE, then replacing the thing should be
cheaper.
