elhammavis
Dec 13, 2020Tutor
Reset router
Hi The router cannot be reset. When I push the reset button and it restarts, the routerlogin page asks me for user and password. It must be admin and password. But it does not approve them and force...
Dec 14, 2020Guru - Experienced User
which router is it?
did you push and hold reset for 7-15 seconds while it was powered on? Many just click the button.
elhammavis
Dec 14, 2020Tutor
I hold the button for 10 seconds while power one. It is C3700v2.
- plemansDec 14, 2020Guru - Experienced User
unhook the coax from the modem then try a 30/30/30 reset.
push and hold reset for 30 seconds while powered on.
power it off and continue to hold reset for another 30 seconds
power it back on and continue to hold reset for another 30 seconds.
So a total of 90 seconds holding reset.
then connect the coax back to it and attempt login/setup.
- elhammavisDec 24, 2020Tutor
Thank you so much, It worked!
- plemansDec 25, 2020Guru - Experienced User
Glad it worked for you!
If you mark the answer as solved, it might help the next person
