dsn's avatar
dsn
Tutor
Jan 09, 2016
reset to factory defaults, then restore configuration file?
Quick question: I have read many times that it is a good idea to reset a wifi router to factory defaults before, then again after, flashing a new firmware. What I'm wondering is, do I still get the b...
  • TheEther's avatar
    Jan 09, 2016
    No, you will lose the benefit of resetting if you restore from a configuration file.  In spite of this, many people do it and, more often than not, there are no ill effects.  But the two latest versions of firmware for the R7000 are a prime example where restoring from an older configuration file only leads to grief.
