Sparky913
Sep 09, 2021Follower
reset wifi password
i can t reset my password no matter what i try
Sep 09, 2021Guru - Experienced User
What have you tried?
What happens when you tried?
Details are key. We can't help much off "nothing works".
Worse case scenario, factory reset the router (push and hold reset for 7-15 seconds while powered on). Then simply reinstall it with the ssid/password you'd prefer.
