KLoterbauer
Aug 28, 2017Follower
resetting my password on R6400v2
I need to reset my password on my new purchase, i obviously did not write it down correctly and need to start over
- Sep 14, 2017
Hi KLoterbauer,
1. If you are looking to change the router password, please check the link below.
http://kb.netgear.com/app/answers/detail/a_id/20026
2. If you are looking to change the WiFi password, please check the link below.
http://kb.netgear.com/app/answers/detail/a_id/24096
3. If none are possible, you can start over by resetting the router.
http://kb.netgear.com/app/answers/detail/a_id/9665
Dexter
Community Team
antinode
Aug 29, 2017Guru
> I need to reset my password on my new purchase, [...]
Start at http://netgear.com/support/ , put in your model number,
select Documentation, download the User Manual, and look for "Reset".
> [...] i obviously did not write it down correctly and need to start
> over
And "start over" is exactly what you'll need to do after such a
reset.
