KLoterbauer
Aug 28, 2017Follower
resetting my password on R6400v2
I need to reset my password on my new purchase, i obviously did not write it down correctly and need to start over
- Sep 14, 2017
Hi KLoterbauer,
1. If you are looking to change the router password, please check the link below.
http://kb.netgear.com/app/answers/detail/a_id/20026
2. If you are looking to change the WiFi password, please check the link below.
http://kb.netgear.com/app/answers/detail/a_id/24096
3. If none are possible, you can start over by resetting the router.
http://kb.netgear.com/app/answers/detail/a_id/9665
Dexter
Community Team
DexterJB
Sep 14, 2017NETGEAR Moderator
Hi KLoterbauer,
Dexter
Community Team
DexterJB
Sep 17, 2017NETGEAR Moderator
Hi KLoterbauer,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
