rcbsurfer
Apr 10, 2017Aspirant
Resetting WNDR3400 v3 after power outage
Whenever a power outage occurs, the router needs to be manually shut off and restarted. Shouldn't it restart itself once the power returns? It's aggravating because the router is located at my second...
rcbsurfer
Apr 11, 2017Aspirant
Thanks for your suggestion. However, I currently have and have had previously other routers that automatically restart after a power outage. Is there a setting or something that can be reset on this router that makes it restart itself after a power outage, rather than purchasing another piece of hardware like a UPS?
Thanks
ElaineM
Apr 12, 2017NETGEAR Employee Retired
There's no setting on the router to adjust or tell that it should restart itself.
