ESV31
Nov 17, 2021Follower
Restart after Power failure.
Hi; I have tried to read a bit on these pages, but fail to find an answer to a problem I have. My 6020 WiFi-router stops working after unwanted power failure, i.e. it does not seem to restart autom...
Nov 17, 2021Guru - Experienced User
Netgear has set up a community forum specifically for General Router products. Most of the people who watch that forum are more likely to have experience with older routers and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Be sure to check the power adapter. Try a different power adapter with same volts and amps specs.
Thank you
