ESV31
Nov 17, 2021Follower
Restart after Power failure.
Hi; I have tried to read a bit on these pages, but fail to find an answer to a problem I have. My 6020 WiFi-router stops working after unwanted power failure, i.e. it does not seem to restart autom...
michaelkenward
Nov 25, 2021Guru - Experienced User
ESV31 wrote:
My 6020 WiFi-router stops working after unwanted power failure, i.e. it does not seem to restart automaticly. Can that be right? Does the R6020 really need a manual restart?
What do you mean by does not restart?
Does the router come on and not connet to the Internet? Or does it just sit there doing nothing, with no LEDs showing signs of action?
If it does come on, but fails to connect, then what does the modem, if there is one, do? Does it come on and connect?
I ask because some modems can take so long to get on line that the router times out while it sits there waiting.
