KLAUS6622
Aug 27, 2022Aspirant
restore on R6400V2
I have TWO R6400v2 routers. Can I skip the tedious task of copying each and every setup parameter by just restoring the correct and tested backup from one router to the next?
- Aug 27, 2022
If they're the exact same versions and models, yes. If they're different, then I wouldn't.
Also, if you're having issues, I wouldn't either as problems in settings can be carried over through backups.
Aug 27, 2022Guru - Experienced User
