Gabarria
Sep 08, 2021Aspirant
Rete Mesh con due Netgear EX6250
Buongiorno a tutti, la mia situazione è questa: un EX6250 è collegato via ethernet (ad un router che non genera nessun wifi) come AP generando la rete che chiameremo Pippo (ok funziona tutto fin...
Sep 08, 2021Guru - Experienced User
If you hardwire in another access point, it doesn't automatically create a mesh. You can set it with the same ssid/passwords but it doesn't enable the smart roaming features that they use when setup in extender/mesh. Just meaning devices won't roam as well as if you'd setup an actual mesh system. But it'll still work.
