Gabarria
Sep 08, 2021Aspirant
Rete Mesh con due Netgear EX6250
Buongiorno a tutti, la mia situazione è questa: un EX6250 è collegato via ethernet (ad un router che non genera nessun wifi) come AP generando la rete che chiameremo Pippo (ok funziona tutto fin...
Gabarria
Sep 09, 2021Aspirant
But mesh don't run even if only first is hardwired with router and the other extend wifi created by the first? and, last question, if both are hardwired with same router?
Thanks for the previous answer
Sep 10, 2021Guru - Experienced User
I'm not sure what you're trying to say here.
The EX6250 is a mesh extender. It isn't a mesh system. the only netgear systems that offer wired and wireless backhaul connections in mesh is the orbi or MK series of nighthawk. The others a simple mesh extenders. If hardwired and ran as access points, they're not mesh devices. they can be set with the same ssid but their smart roaming isn't enabled and so devices won't roam the same
