jcruz123
Jan 07, 2022Follower
RMA faulty power adapter
Hi, We bought a handful of GS110MX 10port/1G port unmanaged switch for our Intel NUCS we have standing at work. The switch is working fine but the power adapter that came with the it is not worki...
Jan 07, 2022Guru - Experienced User
You'd have to go through support for that.
You also posted in the router forum. If you're needing help from the community, I'd post in the switch forum next time.
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days.
