jcruz123
Jan 07, 2022Follower
RMA faulty power adapter
Hi, We bought a handful of GS110MX 10port/1G port unmanaged switch for our Intel NUCS we have standing at work. The switch is working fine but the power adapter that came with the it is not worki...
michaelkenward
Jan 08, 2022Guru - Experienced User
jcruz123 wrote:
We bought a handful of GS110MX 10port/1G port unmanaged switch for our Intel NUCS we have standing at work. The switch is working fine but the power adapter that came with the it is not working at all.
All of the adapters? (You say you bought a handful.)
While you are waiting for Netgear – or, ideally, the outfit that sold you the switch – to deal with your issue you could use just about anything compatible as a substitute. Netgear's adapters are industry standard. Any generic adapter will work, as long as it has the right volts, enough amps and a tip with the right (+/-) polarity and dimensions.
Then again, you have probably discovered that because you say that the switches are working.
By the way, issues with switches are best dealt with in the appropriate section and not in a place where the topic is General WiFi Routers (Non-Nighthawk and Non-Orbi).
If you have more problems, try here:
