FrustratedIN
Oct 28, 2015Tutor
Roku or Amazon streaming stick does't connect to WNDR3400 router
I have a WNDR3400 wireless router and am having trouble connecting a streaming media device. I have tried both a Roku and Amazon streaming stick. During installation, the streaming device can see my ...
- Oct 28, 2015
Try changing the Wi-Fi password to something simpler. Maybe, the Roku or Amazon can't handle special characters. Keep in mind that Wi-Fi passwords are case sensitive.
Hmm, your original post said that they can't connect with no security at all. That's really weird. Try performing a factory reset.
FrustratedIN
Oct 28, 2015Tutor
Hi: All my devices connect to the 2.4 GHz network, so this is what I tried. I also tried the Roku on the 5 GHz network, without success. What is weird (actually frustrating) is that the streaming devices "see" what I am doing. So when I have the security on, my network displays as locked. When I shut off the security, my network shows as open. This tells me that the router is recognized, and signal strength is ok. Thanks.
TheEther
Oct 28, 2015Guru
- FrustratedINOct 28, 2015Tutor
The factory reset solved the problem, thank you! Was hesitant to do this as I use access control and I had to reenter all the device MAC addresses. I found the router was acting weird since I updated the firmware a few weeks ago. Should have known. Thanks again.
