WARNERP42
Jan 08, 2022Tutor
Roomba i3
I recently purchased an iRobot Roomba i3 but have been unable to set it up due to Wi-Fi connection issues. I run through the Roomba set up, but when it gets to the point of connecting to Wi-Fi I get ...
- Jan 12, 2022
After 3+ weeks of trying to resolve this issue with the Roomba, I'm giving up and returning it unless their tech support gets back to me ASAP. I even tried opening up the guest Wi-Fi connection and nothing different happened - the robot wouldn't connect. :-(
WARNERP42
Jan 10, 2022Tutor
I have purchased a new NETGEAR Nighthawk AC1900 R7000 Wi-Fi Router. Still trying to resolve the iRobot Roomba i3 issue however. NETGEAR technical support did not have any suggestions when I called them.
- michaelkenwardJan 11, 2022Guru - Experienced User
It isn't really a Netgear problem. Roomba made the device.It should advise you on how to connect to the wifi from the router.
This issue is not new. Try this:
Search - NETGEAR Communities – Roomba
These issues often come down to the useless apps from the makers of IoT devices. They cannot tell the difference between 2.4 GHz and 5 GHz on the device you use to set up the IoT thing.
I can see nothing in the administrative screen that would be causing an issue and cannot find anything regarding 2.4 vs. 5 GHz in the settings. I do not know enough about Wi-Fi to go changing things in the settings.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Specify Basic WiFi Settings.There may also be some helpful videos on what to do.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.You can temporarily disable the 5 GHz wifi, set up the IoT toy and then turn the 5 GHz wifi back on.
- WARNERP42Jan 12, 2022Tutor
