rvk11104
Jun 07, 2023Follower
Router as extender question
I have a R6400v2 router that I used as my router. However, my ISP has now replaced it with their own router/modem all in one. Question is, is it possible to use my 6400v2 as just a range extender as ...
michaelkenward
Jun 09, 2023Guru - Experienced User
rvk11104 wrote:
Question is, is it possible to use my 6400v2 as just a range extender as now the wifi does not reach the other side of the house?
Wireless repeater or Access Point wired to the router?
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Enable bridge mode.
There may also be some helpful videos on what to do.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
