Waynefi
Dec 30, 2016Aspirant
Router blocking 1 website
Hello, I have read through the other similar discussions. One specific website has stopped connecting thru my router. This started all of a sudden a few weeks ago. Devices that I can bypass the r...
- Jan 08, 2017
Thanks to all who tried to help. Through process of elimination, I decided to exchange the modem under warranty. Installed the new upgraded modem, had it activated by my ISP WOW, and the site is back ??
Whatever, it worked, sad though the hours and hours spent trying to figure this out.
Trikein
Dec 30, 2016Luminary
What website is it? Also, have you tried pinging it? Windows Key + R > CMD > Ping <website.com>. If the ping doesn't work, try "Tracert <website.com>". To copy/paste, right click on CMD windows and click "Select Al" and then press enter and paste into reply.
Waynefi
Smith-wessonforum.com
Ping timed out
Tracert reports destination host unreachable
Yet, i can bypass router and go right there.
- TrikeinDec 31, 2016Luminary
Can you post the tracert? Just looking to see if the website resolves to IP 208.71.128.50 or not. If it doesn't, can you post a tracert to 208.71.128.50 directly? Trying to see if its a DNS or firewall issue.
- WaynefiDec 31, 2016Aspirant
Microsoft Windows [Version 10.0.14393]
(c) 2016 Microsoft Corporation. All rights reserved.C:\Users\Wayne>tracert smith-wessonforum.com
Tracing route to smith-wessonforum.com [208.71.128.50]
over a maximum of 30 hops:1 <1 ms <1 ms <1 ms 192.168.1.1
2 * 192.168.1.1 reports: Destination net unreachable.Trace complete.
C:\Users\Wayne>tracert 208.71.128.50
Tracing route to mail.smith-wessonforum.com [208.71.128.50]
2 10 ms 23.28.124.1 reports: Destination host unreachable.Trace complete.
C:\Users\Wayne>
It looks to be resolving to the correct IP but isn't routing. Can you post a tracert to the same IP when connecting direct to the modem? Also, do you have any parantal controls set up with W.O.W or on the router?
The trace looks to be getting to your ISP, so that tells me its making it past your router, but your ISP isn't allowing it to route. Maybe it works when directly connected because you are getting a different IP when bypassing the router, and that IP block routes?
