Waynefi
Dec 31, 2016Aspirant
Router blocking 1 website
Hello, I have read through the other similar discussions. One specific website has stopped connecting thru my router. This started all of a sudden a few weeks ago. Devices that I can bypass the r...
Waynefi
Microsoft Windows [Version 10.0.14393]
(c) 2016 Microsoft Corporation. All rights reserved.
C:\Users\Wayne>tracert smith-wessonforum.com
Tracing route to smith-wessonforum.com [208.71.128.50]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.1.1
2 * 192.168.1.1 reports: Destination net unreachable.
Trace complete.
C:\Users\Wayne>tracert 208.71.128.50
Tracing route to mail.smith-wessonforum.com [208.71.128.50]
2 10 ms 23.28.124.1 reports: Destination host unreachable.
Trace complete.
C:\Users\Wayne>
Trikein
Dec 31, 2016Luminary
It looks to be resolving to the correct IP but isn't routing. Can you post a tracert to the same IP when connecting direct to the modem? Also, do you have any parantal controls set up with W.O.W or on the router?
The trace looks to be getting to your ISP, so that tells me its making it past your router, but your ISP isn't allowing it to route. Maybe it works when directly connected because you are getting a different IP when bypassing the router, and that IP block routes?
- WaynefiDec 31, 2016Aspirant
I did try going directly PC to modem, but had the same result. Before I forget thanjs for your interest and help !!!
I have never played with any parental controls from the ISP or Netgear, or Norton for that matter.
The only way I reach that one site from here is through Ipad and I phone with the WiFi disconnected on the device.
This is what happened with the PC direct to modem:
(c) 2016 Microsoft Corporation. All rights reserved.C:\Users\Wayne>tracert smith-wessonforum.com
over a maximum of 30 hops:1 12 ms 12 ms 12 ms 23.28.124.1
2 12 ms 10 ms 17 ms dynamic-76-73-172-89.knology.net [76.73.172.89]
3 11 ms 12 ms 12 ms 76-73-168-108.knology.net [76.73.168.108]
4 16 ms 12 ms 13 ms 76-73-168-106.knology.net [76.73.168.106]
5 11 ms 11 ms 11 ms 76-73-168-104.knology.net [76.73.168.104]
6 23 ms 23 ms 22 ms static-69-73-0-141.knology.net [69.73.0.141]
7 24 ms 25 ms 22 ms dynamic-75-76-35-8.knology.net [75.76.35.8]
8 24 ms 26 ms 23 ms ae14.cr1-chi1.ip4.gtt.net [77.67.77.109]
9 46 ms 46 ms 45 ms xe-1-0-2.cr1-nyc4.ip4.gtt.net [89.149.134.117]
10 * * * Request timed out.
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
21 * * * Request timed out.
22 * * * Request timed out.
23 * * * Request timed out.
24 * * * Request timed out.
25 * * * Request timed out.
26 * * * Request timed out.
27 * * * Request timed out.
28 * * * Request timed out.
29 * * * Request timed out.
30 * * * Request timed out.Trace complete.
C:\Users\Wayne>
- StephenBDec 31, 2016Guru - Experienced User
If you can't connect to the site when you are bypassing the modem, then it isn't the router doing the blocking.
It does look like a routing issue, since DNS did resolve the address. So I suggest contacting your ISP.
FWIW Verizon Fios will let me access the site, and ping also works for me.
- TrikeinDec 31, 2016Luminary
I am also on Verizon FIOS (RI) and can access it. Here is tracert.
1 8 ms 2 ms 1 ms router.asus.com [192.168.1.1]
2 5 ms 4 ms 7 ms lo0-100.PRVDRI-VFTTP-315.verizon-gni.net [72.92.234.1]
3 10 ms 6 ms 7 ms B3315.PRVDRI-LCR-22.verizon-gni.net [100.41.0.144]
5 13 ms 14 ms 14 ms 0.xe-1-1-0.IL2.NYC9.ALTER.NET [152.63.26.66]
6 14 ms 14 ms 14 ms 0.ae8.GW10.EWR6.ALTER.NET [140.222.231.131]
7 13 ms 14 ms 14 ms customer.customer.alter.net [157.130.91.86]
8 14 ms 22 ms 14 ms techie-ic-133875-nyk-b2.c.telia.net [213.248.79.2]
9 14 ms 14 ms 14 ms mail.smith-wessonforum.com [208.71.128.50]
Trace complete.Second, here is a tracert from GTT's looking glass out of Chicago. Notice it routes to et-8-1-0.cr8-nyc3.ip4.gtt.net instead of xe-1-0-2.cr1-nyc4.ip4.gtt.net.
IPv4 traceroute to 208.71.128.50 traceroute to 208.71.128.50 (208.71.128.50), 12 hops max, 52 byte packets 1 et-8-1-0.cr8-nyc3.ip4.gtt.net (89.149.180.206) 26.181 ms 24.544 ms 24.151 ms MPLS Label=417607 CoS=0 TTL=1 S=1 2 xe-2-0-1.cr1-nyc4.ip4.gtt.net (89.149.134.125) 24.287 ms xe-1-2-2.cr1-nyc4.ip4.gtt.net (89.149.134.121) 23.352 ms xe-1-0-2.cr1-nyc4.ip4.gtt.net (89.149.134.117) 24.041 ms 3 techie-media-gw.ip4.gtt.net (77.67.71.18) 164.708 ms 28.815 ms 202.420 ms 4 mail.smith-wessonforum.com (208.71.128.50) 22.930 ms !<10> 24.205 ms !<10> 25.478 ms !<10>Also, do you live in MI? Seems like there are some issues with WOW in MI.See thread here. Overall I would suggest contacting your ISP and see if there are outages in your area. If not, then ask for Tier 2 (I hear bad things about WoW support) and see if they tracert to the site.
