Waynefi
Dec 31, 2016Aspirant
Router blocking 1 website
Hello, I have read through the other similar discussions. One specific website has stopped connecting thru my router. This started all of a sudden a few weeks ago. Devices that I can bypass the r...
- Jan 08, 2017
Thanks to all who tried to help. Through process of elimination, I decided to exchange the modem under warranty. Installed the new upgraded modem, had it activated by my ISP WOW, and the site is back ??
Whatever, it worked, sad though the hours and hours spent trying to figure this out.
Waynefi
Jan 05, 2017Aspirant
Actually, I can go next door and get the site in question using the same ISP.
Jan 05, 2017Guru - Experienced User
I misread your earlier post saying that you connected normally when you bypassed the router (I thought you said it failed both ways).
So Mac spoofing is worth a try (setting the router WAN mac address to match the PC that works when you do the bypass). It is weird though.
