Solarsails
Apr 26, 2019Aspirant
Router. Can't pull time from NTP SERVER because not connecting to network through WAN port!
I don't want to use WAN port on inside segment of network.
I'm so close to switching to dedica...
- Apr 26, 2019
Without the WAN port configured and connected, the usability as a router is a little bit hmmmmmmmm. These are consumer routers, intended to be used and deployed as documented.
Using the WNDR3400v2 as a pure wireless access point only probably - and it's configured accordingly?
schumaku
Apr 26, 2019Guru - Experienced User
- SolarsailsOct 07, 2019Aspirant
Yes, Configured as Access Point. Its not such a terrible bug as I implied; I suppose I should start writing my own firmware for as many netgear routers that I unbrick. This 3400v2 is a nice little, stable router (sometimes a little warm around the edges) With a couple high gain external antennas I would think that it would perform fabulously) Your point is well taken. Thank you and I bid you good day.
