Automaan
Feb 24, 2021Follower
Router DGN2200v4 unable to install firmware update.
Followed all the instructions for the firmware update. Everything looked to be be going fine. but got an error message at the end of the process stating "routerlogin.net's server IP address could not be found." checked just to be sure, and stilll running V1.0.0.102
Not sure what to do next????
1 Reply
> Router DGN2200v4 [...]
> [...] stilll running V1.0.0.102
So it still works after the update apparently failed?
What, exactly, are you trying to load into it?
> Followed all the instructions for the firmware update. [...]
"Followed all" _which_ "the instructions [...]"?
> [...] got an error message at the end of the process stating
> "routerlogin.net's server IP address could not be found." [...]More context might be helpful. After a firmware load, the router
must restart, and while it does that, your web browser won't be able to
communicate with it.
> Not sure what to do next????Not sure what you did before.
Possibly interesting:
