cflucky
May 26, 2025Follower
Router drops internet connection
I have an AC1750 Smart WiFi Router, Model R6350. Recently it is dropping my internet connection about every 24 - 48 hours. I unplug the power for about 10 seconds and replug and it re boots. Is there a solution to fix this problem, or is it time for a new router?
1 Reply
Does the internet LED on the router turn AMBER or OFF when this happens?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.What channel configurations are currently set on the router?
Maybe time for something new.
