JensB's avatar
JensB
router drops randomly
Firmware version V1.0.0.32   sometimes this router just drops randomly. Only 1 light burns then which is the power light ( amber color ).  After a minute the router restores itself and i have inter...
  • JensB's avatar
    JensB
    May 05, 2016
    ye i checked cables aswell, the power was correctly placed, aswell as ethernet cables. So might just be a loose connection somewhere in the router,
    it still didnt drop since the reset, so i hope this will stay. If this problem does come back i might just send this router back to the shop i bought it from to get a new one
    Kind regards
    jens
