JensB
Apr 06, 2016Aspirant
router drops randomly
Firmware version V1.0.0.32 sometimes this router just drops randomly. Only 1 light burns then which is the power light ( amber color ). After a minute the router restores itself and i have inter...
- May 05, 2016
ye i checked cables aswell, the power was correctly placed, aswell as ethernet cables. So might just be a loose connection somewhere in the router,
it still didnt drop since the reset, so i hope this will stay. If this problem does come back i might just send this router back to the shop i bought it from to get a new one
Kind regards
jens
JensB
Apr 08, 2016Aspirant
i did what you said, altho i found something interesting in the logs from the router itself. It says that the router was attacked by a ddos attack from some weird ip adress. Could this have something to do with it ? it happens multiple times in a like a time span of 5 minutes. i will check the logs later if my router goes down again. And if the attacks are back on the logs then that might be the problem
kind regards
jens
JensB
had same problem again, and router dropped due to a ddos, i don't know how i should fix this
