JensB
Apr 06, 2016Aspirant
router drops randomly
Firmware version V1.0.0.32 sometimes this router just drops randomly. Only 1 light burns then which is the power light ( amber color ). After a minute the router restores itself and i have inter...
- May 05, 2016
ye i checked cables aswell, the power was correctly placed, aswell as ethernet cables. So might just be a loose connection somewhere in the router,
it still didnt drop since the reset, so i hope this will stay. If this problem does come back i might just send this router back to the shop i bought it from to get a new one
Kind regards
jens
