JensB
Apr 06, 2016Aspirant
router drops randomly
Firmware version V1.0.0.32 sometimes this router just drops randomly. Only 1 light burns then which is the power light ( amber color ). After a minute the router restores itself and i have inter...
- May 05, 2016
ye i checked cables aswell, the power was correctly placed, aswell as ethernet cables. So might just be a loose connection somewhere in the router,
it still didnt drop since the reset, so i hope this will stay. If this problem does come back i might just send this router back to the shop i bought it from to get a new one
Kind regards
jens
JensB
Apr 11, 2016Aspirant
does anyone have a solution for this problem ? Or does netgear have an update for this problem
kind regards
jens
ElaineM
Apr 11, 2016NETGEAR Employee Retired
JensB Did you try to contact your ISP and ask for a new Internet IP address?
kbrewster Do you have the same model number of router?
In your case, try to reflash the firmware and then reset it after.
If you get the same thing, try using an older firmware.
By the way, don't forget to reset every after reflash or fw downgrade.
- JensBApr 12, 2016Aspirant
i called my isp company yesterday and they did a check on the company's modem which supplies the internet in my house. The modem itself is okay and there were no signs of a dos attack on those logs.
Anyways they said to shut down the modem for 10 minutes & then reactivate it (modem would automaticly give new ip adresses then). But that did not help anything. Router from netgear still goes down 20 times in a couple of minutes when my modem ( which is a wifi router aswell but bad range, that's why i have the netgear one ). is still online broadcasting wifi-signals. So the problem is on this netgear router. I resetted it again today, and my computer saw it as a new router.
So i thought, well mayby its fixed, but then again it dropped a couple of times, please can just someone help me with this, cuz its so annoying.
Kind regards,
jens
- JensBApr 17, 2016Aspirant
[admin login] from source 192.168.1.4, Sunday, April 17, 2016 17:16:39
[DoS Attack: ACK Scan] from source: 31.13.91.6, port 443, Sunday, April 17, 2016 17:15:17
[DHCP IP: 192.168.1.8] to MAC address 44:6d:6c:57:52:df, Sunday, April 17, 2016 17:14:52
[DoS Attack: ACK Scan] from source: 31.13.91.6, port 443, Sunday, April 17, 2016 17:14:29
[DHCP IP: 192.168.1.4] to MAC address 30:52:cb:11:bb:11, Sunday, April 17, 2016 17:14:05
[DoS Attack: ACK Scan] from source: 179.60.195.7, port 443, Sunday, April 17, 2016 17:13:50
[Time synchronized with NTP server] Sunday, April 17, 2016 17:13:44
[Internet connected] IP address: 192.168.0.192, Sunday, April 17, 2016 17:13:32
[Initialized, firmware version: V1.0.0.32] Sunday, April 17, 2016 17:13:30thats from today, router went down twice today so far
