JensB
Apr 06, 2016Aspirant
router drops randomly
Firmware version V1.0.0.32 sometimes this router just drops randomly. Only 1 light burns then which is the power light ( amber color ). After a minute the router restores itself and i have inter...
- May 05, 2016
ye i checked cables aswell, the power was correctly placed, aswell as ethernet cables. So might just be a loose connection somewhere in the router,
it still didnt drop since the reset, so i hope this will stay. If this problem does come back i might just send this router back to the shop i bought it from to get a new one
Kind regards
jens
ElaineM
May 03, 2016NETGEAR Employee Retired
Did you try changing the cable between the modem and router?
If the connection from the modem is working fine, perhaps it could be a hardware problem.
You may want to consider upgrading your router to a newer one.
JensB
May 05, 2016Aspirant
Kind regards
jens
- ElaineMMay 05, 2016NETGEAR Employee Retired
Glad to hear that it's working after the reset.
Thank you for keeping us updated.
