CookieMaster
Nov 30, 2015Aspirant
Router IP Login same as Modem
Please note I did enable ap mode. It appers my router's Ip login is the same for my modems. I now can't seem to log into the routers admin page at all. How would I fix this? I have a Netgear R625...
- Nov 30, 2015
One suggestion is to connect your route diectly to your computer and change its IP.
If the Router IP is not the default IP, you can reset the router too.
Hope it helps
PASBM
Nov 30, 2015Tutor
Hope it helps
CookieMaster
Thank you, didn't actualy change anything, pluged it in and it gave a slighlty different IP. Resolved.
