tcham2019's avatar
tcham2019
Router is not reaching the expected range Netgear N300
My Router is supposed to be reaching 300 but it's only reaching at 50. What can I do?
  • antinode's avatar
    Mar 09, 2019
    > [...] Netgear N300
       "N300" is a speed, not a model number.  Ever helpful, Netgear
    product packaging emphasizes speeds like "Nxxx", but that's not the
    model identifier.  Look at the product label.
    > [...] expected [...] supposed [...]
       By whom?  Visit http://netgear.com/support , put in your (actual)
    model number, and look for Documentation.  Get something like a Product
    Data Sheet, and read the fine print.  Expect to find a disclaimer like
    the following:
          Maximum wireless signal rate derived from IEEE standard 802.11
          specifications.  Actual data throughput and wireless coverage will
          vary.  Network conditions and environmental factors, including
          volume of network traffic, interference, and building construction
          may lower actual data throughput and wireless coverage. [...]
    > [...] it's only reaching at 50. [...]
       When you do what?  You can connect an old, lame client device to the
    fastest router in the world, and still get a slow connection.
    > [...] What can I do?
       If your router is the bottleneck, then a faster router might help.
