u2khanh4
Feb 23, 2022Initiate
Router Login AFTER completing Day Zero login page
Hello! My goal is simply to rename my SID and register with Facebook wifi. However, I'm not able to enter the router Access Point after i complete the Day Zero easy setup. ------- I've reset m...
- Feb 24, 2022
Glad it worked!
If you mark it as solved, it keeps others from trying to fix it again :)
Feb 23, 2022Guru - Experienced User
after initial setup, your AP should be getting its IP address from the primary router.
so log into your primary router and see if its attached devices page has the ip address of the AP. use that to access it
- u2khanh4Feb 24, 2022Initiate
Ah. that's how it works? Wonderful.
I've logged onto my router, found the connected device, looked at the IP address, and used that address in the web browser. MUCH APPRECIATED! Thanks again!
- plemansFeb 24, 2022Guru - Experienced User
Glad it worked!
