jake5584
Jan 20, 2019Follower
Router login and password issues
I purchased Netgear router R6250 (AC1600) about 2 years ago and set everything up. 18 months ago i moved to a place that provided internet (so I boxed up my router). I just finished moving again went...
- Jan 20, 2019
Try logging into the router by using its IP address. Typically it would be 192.168.1.1. To make sure, you can find your default gateway, and that will be where your router is located. Once you find it and you get the login screen, it will be UN:admin PW:password (unless you changed it). You'll be able to find the wifi settings in the web admin page.
Otherwise if the sticker is still attached to the back or underside, it may be the default wifi password that came with the router.
WHOA
Jan 20, 2019Guide
- WHOAJan 20, 2019Guide
That should've read:
UN: admin PW: password
Also, I don't believe there's an easy way to reveal the password ON the connecting device. Like you can't just go into your laptop's settings and see that the wifi password is "123456abcdefg".
- wcalifasJan 21, 2019Prodigy
Make sure when you connet your computer to the router its connected to one of the four LAN ports on the back of the router. You can always press the reset pinhole with a paper clip for 30 seconds to reset it back to defaults and see if it will respond but it will go back to defaults.
- michaelkenwardJan 21, 2019Guru - Experienced User
To retrieve forgotten wifi passwords, install the Windows desktop version of the genie on your laptop. (Unless it is a Mac, of course.) There is a "Retrieve wireless password" at the top.
Some people consider this as a crime against society, but you need to be able to login to the genie to get there, so there is some security. You also have to be connected to the wifi in the first place, which, as you have discovered, isn't easy if you don't know the password. Fortunately, your laptop does know it, even if you don't!
