jake5584's avatar
jake5584
Follower
Jan 20, 2019
Router login and password issues
I purchased Netgear router R6250 (AC1600) about 2 years ago and set everything up. 18 months ago i moved to a place that provided internet (so I boxed up my router). I just finished moving again went...
  • WHOA's avatar
    Jan 20, 2019
    Try logging into the router by using its IP address. Typically it would be 192.168.1.1. To make sure, you can find your default gateway, and that will be where your router is located. Once you find it and you get the login screen, it will be UN:admin PW:password (unless you changed it). You'll be able to find the wifi settings in the web admin page.
    Otherwise if the sticker is still attached to the back or underside, it may be the default wifi password that came with the router.
