PB38
Oct 02, 2023Aspirant
Router Login Issues for Model R6400 V2
Been having trouble using the Router Log with User Admin and my password. I'm having problems with WiFi connections so wanted to see if all my items are connected properly Thanks
Oct 02, 2023Guru - Experienced User
what trouble with it are you having?
What firmware is on your device
what modem/gateway is it connecting to?
- PB38Oct 02, 2023Aspirant
As I stated I'm trying to to log into the "Router Login" - using the User login Admin and my password nothing happens.
Is this no longer available. I have Spectrum WiFi, so my TV and my cell (Samsung) and HP printer are all connected. I'm not a computer "geek" only a 79 year old who wants to see if things are connected to the Router
- michaelkenwardOct 03, 2023Guru - Experienced User
Is this using a browser from a PC wired to the router?
Is this using the address routerlogin.net or an IP address?
Has this just started happening?
What is Spectrum wifi?
As plemans says it would also help if you told us what the modem/gateway is that connects the router to the Internet.
