FrenchMassacre
Nov 17, 2016Follower
Router Login page connection refused..
Hi Guys, I have a Netgear TrendNet TEW-639GR that I want to use at my grandmas (used it as an access point a few years back) Tried to reset it to factory defaults (hold the reset button for 20...
- Retired_MemberNov 17, 2016
download the manual from trendent this is not a Netgear product you are on a netgear site. I looked briefly for the reset procedure but only found the procedure to use if logged in to router
http://www.trendnet.com/asp/download_manager/inc_downloading.asp?iFile=15269
Retired_Member
Nov 17, 2016download the manual from trendent this is not a Netgear product you are on a netgear site. I looked briefly for the reset procedure but only found the procedure to use if logged in to router
