dolbec
Jul 20, 2021Follower
Router login
When I went to the router login.net site and put in my information a check came up to get me to some technical customer support. Is that legit? They said they were computer services of Texas
1 Reply
> When I went to the router login.net site [...]
"router login.net" is not a valid name. "routerlogin.net" is. With
my weak psychic powers, I can't see what you actually typed.> [...] Is that legit? [...]
Probably not. If you misspell "routerlogin.net", then you might go
to some scam-artist site. If you actually do a Web search, then there's
no telling where you might end up.If the URL wherever you end up does not include "netgear.com/", then
you might be in a place where you don't want to be.> [...] They said they were computer services of Texas
Does that sound to you like your own router? Your own router is
where "routerlogin.net" should take you. If you spell it right.
