McDonough
Apr 18, 2020Aspirant
Router Mode
I've got a several year old Netgear C3000 modem/router and somehow inadvertently set it to router mode which of course disabled the modem mode. So now I can't connect to the intenet to repair it. I...
- Apr 19, 2020
Thanks for haning in there on this one! Regarding page 7, the item labeled "WiFi On/Off button" has an LED adjacent to it that used to be lit when Netgear was performing its wireless router function. It no longer illuminates. I have unplugged the device for 30 minutes, I have pressed the on/off switch at the bottom of the unit as shown on page 9 of the manual. Each time the unit comes back up, it is still lacking both the illuminated wireless LED and of course it does not perform the wireless function. All I wanted to accomplish was to return the unit to its factory default settings which as I recall had the unit operating as both a mofdem and router.
I'd like to be able to do that but in the meantime, I've attached a spare router to the C3000 and it works, so now the C3000 is acting as solley a modem while the attached router does the rest.
That's the best I can do. Happy to be told what I'm doing wrong, but I suppose it's possible that the router portion of the C3000 is shot. Thanks again for your effort.
antinode
Apr 19, 2020Guru
> [...] I have rebooted the system several times theoretically back to
> factory settings, [...]
"reboot" equals "restart", which does not affect the settings;
"reset" affects the settings. Again, what, exactly, did you do?
> [...] but the wireless component is not reactivated.
Which part of "Evidence?" was unclear?
> [...] Nothing happens when I press the wifi button next to the light
> that would be illuminated if wifi were working.[...]
What does Netgear call these things? "press" how (long)?
> [...] I'm obviously a novice at this [...]
Ignorance is often curable, but the less you know, the more important
accurate, detailed, precise descriptions become. (And the less value
your analysis may have.)
> [...] I did read the user manual [...]
Not much evidence for that, either. See "Figure 2. Modem router
front view", page 7. Which "the wifi button" is "next to" which "the
light"?
McDonough
Apr 19, 2020Aspirant
