COG's avatar
COG
Follower
Jun 26, 2016
Router model with WPS
Hi my tv has WPS button my router Model N300 [WNR2200] has no WPS button. What router would I need to connect to Broadband ?
  • Retired_Member's avatar
    Retired_Member
    Jun 26, 2016
    Any router with a WPS option. Or use your router and enter the correct security settings.
    Retired_Member
  • WPS is for convenience not a MUST to have. Always you can manually set up wireless devices. R7000 has WPS button. Remember there are hardware button and software button depending on which router you get. Hardware button you just push the button, software button you have to log into router GUI, go to wireless set up page to click the button with mouse.
